Melting effect
Ali Mohamed
Melting effect
on Dec 11, 2014 at 1:12:28 pm
Hey guys..
So I'm busy with a small piece of animation and just got a little bit stuck..
I'm busy animating a webpage during it I want to make a webpage melt to reveal something behind it. If anyone can help me with the best way to go about this it would be much appreciated.
John Cuevas
Re: Melting effect
on Dec 11, 2014 at 4:26:06 pm
Not sure this is the best way to do it, but I just made a little test using CC mercury as a bottom layer to produce some droplets. Top layer, CC Blobbylize that was using a simple fractal noise to drive it, came out pretty nice, might give you some ideas to use.
Here's my quick project: 8291_meltingwebpagefolder.zip
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Derek Boettcher
Re: Melting effect
on Dec 12, 2014 at 10:49:40 pm
John's effect was a pretty great technique. You can also add in force motion blue and adjust the parameters to allow it to look a little more realistic. you can also tighten up the fractal noise a bit and change the birth rate and blob birth/death sizes too, minor tweaks, but he was definitely drawing up something cool
Best,
Derek Boettcher
Creative Management
BTH Media Group
http://bthmedia.com
Ali Mohamed
Re: Melting effect
on Dec 15, 2014 at 7:16:41 am
Thanks Guys this has really saves me haha
