text animation preset - ramp up & down
zach hcaz
on Nov 26, 2014 at 8:36:01 pm
hi, I'm looking for a text animation preset in after effects cc which will make my text animate like the text at the start of this video:
i'm fairly new to text animation effects...any help would be appreciated.
John Cuevas
Re: text animation preset - ramp up & down
on Nov 27, 2014 at 2:26:01 pm
Try this free preset: Amortype 2.0 Watch the tutorial, it will show you how to remove/adjust the defaults. In that video it looks like it just uses scale, so you just need set position to 0, unlink the scale and set it to 100,0,100 then uncheck the random colors option. Then adjust the frequency and you should be pretty close.
Here's my quick attempt at it: 8234_scaleup.aep.zip
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
