Keyboard shortcut to set composition duration automatically by layer length
Michael Garske
on Nov 24, 2014 at 4:15:16 pm
Is there a keyboard shortcut or menu option to set the composition duration to the length of the longest layer?
Dave LaRonde
Re: Keyboard shortcut to set composition duration automatically by layer length
on Nov 24, 2014 at 4:50:11 pm
drag the clip you want onto the make comp icon at the bottom of the project pane and you're all set
Dave LaRonde
Promotion Producer
Michael Garske
on Nov 24, 2014 at 9:27:29 pm
If I trim the in/out point of a clip once it's in a composition is there a way to set the comp duration to the length of the trimmed layer?
Dave LaRonde
on Nov 24, 2014 at 9:46:10 pm
Go to the clip's in-point. Hit b on the keyboard. You've just set the beginning of the comp's work area.
Go to the clip's out-point. Hit n on the keyboard. You've just set the end of the comp's Work Area.
On AE's menu at the very top -- File, Edit, etc. -- go to Composition>Trim Comp To Work Area.
Done.
Dave LaRonde
Promotion Producer
