• | adding blur text animation preset movement?
on Nov 19, 2014 at 4:41:15 pm |
It's easy to add motion blur on titles moved using the regular position parameter but when the movement comes from a text animation preset, it doesn't seem to work. Is this the nature of the animal?
Paul
• | Re: adding blur text animation preset movement? on Nov 19, 2014 at 5:48:55 pm |
Which preset(s) are you using?
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
• | Re: adding blur text animation preset movement? on Nov 19, 2014 at 6:37:16 pm |
Actually they are ones I improvised using the Animate parameters in Text (so I should have not called it a preset). I'm doing a slide on that involves Animate position keyframes as opposed to layer position keyframes.
Paul
• | Re: adding blur text animation preset movement? on Nov 19, 2014 at 7:32:15 pm |
Post a screen grab of your timeline, with the text parameters open, because you can absolutely add motion blur to text, that is animating via text animators.
Thinkck.com
• | Re: adding blur text animation preset movement? on Nov 19, 2014 at 7:47:11 pm |
My Bad - I mixed ip the column header for motion blur with the Master on/off switch above it
