Visible background ad.
Romina Power
on Nov 15, 2014 at 4:47:48 pm
Hello, everyone.
I'm making my graduation film (documentary) .Yesterday I and my cameraman made mistake – we shot light advertising sheet on background.
This interview is important to me . I’m looking for advice, how I make blur background ( or how I “fix” this ad). I can work with After Effects… but unfortunately I’m beginner .
Is there hope for me?
Graham Macfarlane
Re: Visible background ad.
on Nov 15, 2014 at 5:28:20 pm
Hello Romina,
I assume you need to remove the intraceuticals logo (replacing it with white)?
If so, there should be hope!
What duration is this shot?
Graham Macfarlane - CGI specialist
Elyarch Ltd - London UK
3D Studio Max | Vray | Pflow | PhoenixFD | After effects | Mocha
Romina Power
on Nov 15, 2014 at 10:05:08 pm
Videos are very long ( total= 10 min), but I Will edit videos in Adobe Premiere and they must become ~ 3 minutes. Have any ideas? I have RedGiant plugin Can I use them ?
Thank you for support!
John Cuevas
on Nov 15, 2014 at 10:45:53 pm
Assuming you dont want to blur your talent---you are going to need to rotoscope her. Separate her from the background, blur the offending sign in the background. 3 layers, top layer is talent, middle layer is blurred, masked sign area only(including person), bottom layer untouched. The trick is the rotoscoping.
What you want to do is EDIT first, or you would effecting material you won't use. Me, on the top layer, I would do a loose mask around the person, then just feather it. It's pretty much accepted technique for blurring to have it be somewhat loose.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Romina Power
on Nov 16, 2014 at 12:05:05 am
Wouldn't it be easier, if first material has been made shorter ?
Graham Macfarlane
on Nov 16, 2014 at 11:11:59 am
I think John implied making the material shorter by suggesting to do the “edit first”.
For an edited 3 minutes worth of footage, a roto approach, as John has described, should do the trick.
Which RedGiant plugin were you intending to use? One of their keyers?
Since the actress’s face is a light colour with some bright reflections, which are close to the white of the sign, keying might be a little tricky.
Keying could perhaps be used to quickly generate the loose matte John mentions and could even help speed up more detailed keying or roto if required. It all depends how much the lighting changes on the face with respect to the sign.
