Multiple instances does not working parallel using Scripting on Windows Server
Lal XaDa
on Nov 11, 2014 at 3:39:52 pm
Hi all,
i am uploading after effects template to my site, user came and upload his desired contents.
i update the template using scripting with user's contents and then render video so user get video with his uploaded text/images etc.
its working perfectly when i update a single template at a time but when multiple users come at the same time then they need multiple instances of after effects
so i open multiple instances of after effects by using "-m" with after effects shortcut
after looking at windows task manager there are both instances but the problem is
only one instance continue and the second one stop, after completion of first instance the second one still in pause status
i need 2,3 4 or whatever instances to work parallel without pause/stop
i am using windows server 2008 R2 with XAMP installed
