Collapse Transformation
Henrique Zuzz
on Oct 23, 2014 at 1:02:30 am
I Have work in project in After effects. I ´m using layers imported from Illustrator. I activate the collapse transformation, but anything happened. and the image continuous pixelated.
Thanks in advance for the help!
John Cuevas
Re: Collapse Transformation
on Oct 23, 2014 at 1:28:24 am
Is it a vector image? If it is, post a screen grab of your timeline and composition.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Henrique Zuzz
on Oct 23, 2014 at 3:39:43 am
Yes! It is a vector image! And even with the collapse transformations on, lines are pixelated. And any project with any vector image the same thing happens.
The image link.
https://images.creativecow.net/286563/image1.jpg
John Cuevas
on Oct 23, 2014 at 1:53:08 pm
You are zooming into your image(800%). AE is showing you your comp, if you zoomed it that large. Go back to 100% size, select your AI layer, press "s" and then increase the scale to 800%, it will look fine.
Zooming in on your comp is fine--I do it all the time to properly align things, but everything will become aliased when you do that---just like it would if you did that with a picture or movie.
Thinkck.com
