Animating lines
Chris Banks
Animating lines
on Oct 15, 2014 at 9:40:24 pm
Hi there, I wonder if somebody could help me. I am new to after effects and can't seem to find the answer on this..
I am creating a simple animation that has three boxes slowly move around, a simple keyframe on their position, no problem. Next I need to add a line to a corner of each box so that they are all joined - similar to a flow chart etc. So I need to create a line that I can move the two points so that it follows the corners of the boxes. Essentially I think i just need to figure out how to animate two points of a line, but for some reason, im struggling. Any help would be great, thank you very much.
Chris
John Cuevas
Re: Animating lines
on Oct 16, 2014 at 2:41:17 am
Try the Generate Beam effect.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
