Liquid splash in after effects
James Davenport
on Oct 14, 2014 at 4:18:10 pm
I'm looking at a visual effects shot where a drinks cup hits a wall just behind someones head. The cup was a prop and didn't have any liquid in it.
I was wondering if anyone had any ideas of how to add a stain to the wallpaper but to make it act the same way as if a little tea/coffee had been in the cup. So maybe splash outwards a little and then drip down? All within after effects/photoshop maybe.
Any thoughts?
John Cuevas
Re: Liquid splash in after effects
on Oct 14, 2014 at 6:29:11 pm
Do you have Particular, if you do, check out this tutorial. Paint Drips
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
James Davenport
on Oct 14, 2014 at 6:48:34 pm
Thank you! Yes I do have particular. I've watched the tutorial, it's definitely the nearest solution I've seen. Really appreciate your response. I'll try a few different tests.
John Cuevas
on Oct 14, 2014 at 7:20:43 pm
You might also play around with CC Glue Gun, I've made some pretty convincing drips with that too.
Thinkck.com
