Stepped Radial Wipe
Peter Landrey
Stepped Radial Wipe
on Oct 10, 2014 at 3:28:37 pm
I'm using a radial wipe to reveal a segmented "pie" of time. I need the wipe to step 6° per second. I've looked into using an expression to achieve this, but just can't figure it out.
Thanks.
John Cuevas
Re: Stepped Radial Wipe
on Oct 10, 2014 at 4:13:36 pm
Does step mean, it jumps 6 degrees or is it moving the entire second?
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Peter Landrey
on Oct 10, 2014 at 6:05:17 pm
it jumps 6 degrees every second.
thanks.
John Cuevas
on Oct 10, 2014 at 7:07:29 pm
Apply this expression to transition completion:
posterizeTime(1);
time * 1.667;
Thinkck.com
