How to make an image appear out of multiple lines of text
James Brown
on Oct 6, 2014 at 4:06:47 am
How do i achieve an effect where an image appears out of multiple words a lot like what is seen in this
(version 2)
John Cuevas
Re: How to make an image appear out of multiple lines of text
on Oct 6, 2014 at 3:23:01 pm
If you have trapcode particular, you could set up each line/word of text as a custom particle, then set up a grid effect that you animate, then play backwards.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
