Puppet Tool "Rotation Warping" Problem
Hayden Patterson
on Oct 3, 2014 at 5:25:07 pm
Hi everyone,
I'm having a real tough problem with my after effects puppeted character. When I rotate the parent pin on an object (the pins are all expressed to nulls, nulls are parented to eachother), the whole mesh warps, instead of simply rotating along with the parent. If you could take a look at this post I made in the adobe forum, it has all of the information I can give, including screenshots of the problem. Thank you in advance for all suggestions and advice. Post link below:
https://forums.adobe.com/message/6787031#6787031
Hayden
