90 Degree camera Rotation to Greenscreen
Jon Smith
on Sep 20, 2014 at 7:20:04 am
I tried finding an answer, but I'm new to using AE and might not be searching for the correct thing.
I want to replace a hallway with another shot to imply a different room than what's actually there. I went ahead and set up a quick green screen to show what I mean. I've attached a GIF below.
Do I even need a green screen for this shot if I'm replacing a space with no one in the foreground? What's the best way to have this second layer (room) replace the green screen in this camera movement?
John Cuevas
Re: 90 Degree camera Rotation to Greenscreen
on Sep 24, 2014 at 12:41:40 pm
With the hard edges of the door, no, you don't need a green screen. Green screens are used to remove pixels from video, you could easily do that with a mask that tracks the door. The benefit of using a green screen there, is that you won't have to do any tracking.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
