word transforming into antoher word
Arno de Facq
on Sep 9, 2014 at 3:05:09 pm
Hi
I'd like to know how to create the following effect:
The text transforms into another text, but it doesn't just fade, it actually transforms (or it at least looks like that).
Any idea how this was done?
(also: the text being written, is that a particular effect also?)
John Cuevas
Re: word transforming into antoher word
on Sep 10, 2014 at 11:32:06 am
If you mean at 1:20(please provide a time code next time), it's done by using a single mask to write the first words and enabling a mask path. If it was me, the next thing I would do is create another mask and write out my next word, set a keyframe, then copy that keyframe to my first mask. Then just apply Generate Stroke for the writing.
If you have a wacom, you could even use motion sketch to create your words, copy the position keyframes then paste them into the mask properties on a new layer. I tried that with the word capture in this very rush and hurried example. But it should illustrate the technique: 7970_wordtransform.aep.zip
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Arno de Facq
on Sep 10, 2014 at 7:13:59 pm
I though I put a timecode, it seems I forgot, sorry about that!
and yes, that's the very basic that should maker it work, perfect! thanks for the file, I understand perfectly now!
I'll probably be able to use this trick for other tricks.
Thanks again!
