After effects tecniques- Insight
Joseph Ferri
on Apr 11, 2014 at 10:56:54 pm
I'm new to after effects, I'm trying to follow some crash courses on lynda.com so I can learn most possible.
So, I saw this effect in a picture slideshow that I'm trying to replicate, the image zooms and pans in this forest environment using only a couple jpegs as wallpaper, was positioned on the x,y and z axes.
In the video it seems he's zooming into footage, probably the trick was feasible because he had also a lot of tree layers and a chroma key snow effect.
Could you give me a tip or two about the tecniques involved here? So I can look them up and find the lesson area that teaches how to to do it.
I've learned the basic of camera and keyframes.
Stephen Smith
Re: After effects tecniques- Insight
on Apr 14, 2014 at 3:17:09 pm
Any way you can post a link to the clip you are talking about?
Stephen Smith
Utah Video Productions
Check out my Vimeo page
Joseph Ferri
on Apr 16, 2014 at 11:06:16 am
sure..
Stephen Smith
on Apr 16, 2014 at 3:09:13 pm
I would check out these tutorials on building a camera rig. That will help you get from one set of photos to the next smoothly:
Part 1: http://library.creativecow.net/devis_andrew/Animating-a-Camera-1/1
Part 2: http://library.creativecow.net/devis_andrew/Animating-a-Camera-2/1
Part 3: http://library.creativecow.net/devis_andrew/Animating-a-Camera-3/1
Stephen Smith
