Problem with rendering
Ry Low
on Apr 10, 2014 at 3:10:28 pm
Hi guys, I'm pretty new to this.
I've been messing about after watching a tutorial putting some optical flares with smoke in front of a 3d background. Everything looks good until I press render and the background disappears. I have made the flares transparent. I'll post a screenshot below. Any help would be really appreciated.
John Cuevas
Re: Problem with rendering
on Apr 10, 2014 at 3:52:31 pm
Did you turn the background into a guide layer? You can check that, by right clicking the layer and if you see a check mark next to guide layer, click it again to remove the check.
Guide layers are layers you drop into a project just for reference, but they don't render----like a grid you create to line up items.
Johnny Cuevas, Editor
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
© 2018 All Rights Reserved
