Set "Create Proxy Movie" Output Default Settings? CS6
Claudiu Petrescu
on Mar 18, 2014 at 10:24:06 pm
Hello,
I have around 100 folders of cinemaDNG sequences from blackmagic camera and I am using proxies in Premiere.
Is there a way to set the default "CREATE PROXY-> MOVIE" settings so that I do not have to change the settings for each one of those proxies after i've created them?
I managed to set the default output to h264 (instead of the default avi) but that's about it.
I also want to set:
1. default resize to less than 2400x1350
2. Profile to High instead of Normal
3. Target Bitrate
4. Maximum bitrate
It's such a pain to go one by one and change these 4 settings of each proxy...
Ryan Dawson
Re: Set "Create Proxy Movie" Output Default Settings? CS6
on May 9, 2014 at 3:33:27 am
Sounds like you are looking for a script. I myself am not a scripting expert, but I have found useful scripts online for the type of automation you are looking for.
