Optical Flares not showing in AE CS5 effects menu!
Frijo Paul
on Feb 21, 2014 at 9:42:18 am
I downloaded the optical flare plugin and as per instruction I copied the OF folder to the AE plugin folder. But the OF is not showing in my AE effect menu. Can anybody help?
Todd Kopriva
Re: Optical Flares not showing in AE CS5 effects menu!
on Feb 21, 2014 at 3:50:20 pm
Did you install the 64-bit version of the plug-in?
If you're having trouble with a plug-in that you bought from Video Copilot, you can ask them for help:
http://www.videocopilot.net/support
After Effects team blog
John Cuevas
on Feb 21, 2014 at 3:53:09 pm
You also have to install the license for it. There's a little program you need to run to generate the correct code for the license. There's a video on the Copilot site that goes through the entire thing step by step, it's way more involved then it should be, IMO.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Frijo Paul
on Feb 24, 2014 at 10:46:45 am
I think I got the 32 bit version. stupid!!! Thanks anyway.
