after effects and quicktime overlay advice
jason falconer
on Feb 13, 2014 at 7:21:19 am
hello,
my first post here looking for some advice for a relative newbie. I can view quicktime files (.mov) in quicktime player on pc, I can EXPORT quicktime in render queue, but when trying to IMPORT the file ( a full HD overlay grain) it comes up with error message unsupported or corrupt file. The file is fine it plays in vlc and quicktime player.
So anyone know a solution? Is there another format I could convert the file to which will retain alpha layers and quality so I can apply this grain effect?
Jason
John Cuevas
Re: after effects and quicktime overlay advice
on Feb 13, 2014 at 4:21:56 pm
When you made your file what codec did you select. Also what version of AE are you using? Did you render locally or across a network(I sometimes have issues with this and QT)
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
jason falconer
on Feb 14, 2014 at 5:26:35 am
Hi thanks for the reply,
I actually have managed to correct it. I was missing the avid codec and now its installed everything working good :).
Cheers
John Cuevas
on Feb 14, 2014 at 1:16:10 pm
Glad you figured it out. Avid Codecs are pretty good---make sure you step into all the options to turn on Alpha channels for the codec.
Thinkck.com
