No DropZones?
tad newberry
No DropZones?
on Feb 2, 2014 at 12:45:02 am
New here, from FCP and Motion, and am surprised there are no DropZone type objects available. I googled and found a video on AE DropZones, but apparently it was for an older version because i still don't see any way to create a DropZone in my the current AE CC...
Anyone?
thanks for helping out a bonehead!
__________________________
FCS3
2.66 GHz Quad-Core Mac Pro
6GB RAM
NVIDIA GeForce GT 120
...and a few TeraBytes o' storage
(then it's on to PetaBytes, ExaBytes and MosquitoBytes!)
Todd Kopriva
Re: No DropZones?
on Feb 2, 2014 at 2:39:47 am
Not every feature in Motion has an exact parallel in After Effects, and vice versa.
You can submit feature requests here:
http://adobe.ly/feature_request
After Effects team blog
tad newberry
Re: No DropZones?
on Feb 2, 2014 at 2:51:46 am
Thanks, i realize that, but is there anything close in AE? Seems like it is so far advanced there would be some way to drop a video into a template that is pre-sized, filtered, etc.
FCS3
6GB RAM
Steve Brame
Re: No DropZones?
on Feb 2, 2014 at 1:46:19 pm
Create your 'Drop Zone' in your comp and adjust it to your liking.
Select it's layer.
Then Alt-drag your replacement clip from the Project Panel onto the layer in the timeline.
The new clip will inherit all scaling and filters from the original.
Lot's of tutorials online. Search for "After Effects replace footage".
Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia Quadro 4000 * Windows 7 Premium 64bit * System Drive - WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) - WD Velociraptor 10K drive 600GB * Media Drive - 2TB RAID0 (4 - WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC
"98% of all computer issues can be solved by simply pressing 'F1'."
Steve Brame
creative illusions Productions
Matt Davis
Re: No DropZones?
on Feb 17, 2014 at 6:28:56 pm
Listen to Steve Brame. :)
You can use nested comps as "drop zones". I haven't used Motion 4 that much but was a big user of previous versions and I think that will help. Just create a comp within your main comp and use it as you would a drop box.
tad newberry
Re: No DropZones?
on Feb 17, 2014 at 7:19:11 pm
Thanks, Steve. I'll give it a try shortly.
FCS3
6GB RAM
