Rotate word per character
Anastasia Olhovskaya
on Jan 14, 2014 at 5:01:32 pm
I've been interested how to make rotation like here: [00:35]
Can you please help me?
John Cuevas
Re: Rotate word per character
on Jan 14, 2014 at 8:08:58 pm
If you don't need the extra overshoot at the end of the rotation you can accomplish that quickly by using text animators. Create your text, open it up and under "Animate" select "Enable per character 3D". Twirl open the animator and under "Add" choose scale. Twirl open the Range Selector & Advance and choose "Subtract". Set the X and Z rotation to -45 and the scale to 0. Now set keyframes from 0 to 100 for the "End" property of the range selector.
Here's an example file:
To learn more about Text Animators, check out these tutorials: After Effects basics tutorials by Andrew Devis, down towards the bottom.
For more complex animations that can include Over shoot, check out Amortype 2.0
Johnny Cuevas, Editor
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
© 2018 All Rights Reserved
