Is there really a difference the Resolution settings on the comp viewer and the one on the Preview panel?
Sebastian Lee
on Dec 12, 2013 at 5:06:42 am
Title says it all
Tero Ahlfors
Re: Is there really a difference the Resolution settings on the comp viewer and the one on the Preview panel?
on Dec 12, 2013 at 9:28:19 am
Well the difference is that you can set a different preview resolution for just the RAM preview in the preview panel if you want to work in a higher res in the comp window.
Sebastian Lee
on Dec 12, 2013 at 3:38:19 pm
Oh I'm clear about that now. Res in Preview Panel for render depending on the quality you've set but Res in Comp Viewer is the quality of how you see things in the comp viewer. got it! thanks!
