Where in render stack should you use USM?
jim bachalo
on Nov 22, 2013 at 12:14:55 am
I understand there is a psychic processing order or stack in After effects, starting with the bottom layer in a comp and going up, and within each layer, starting with the top effect and going down.
As a best practice, where should USM be used? Always last?(topmost layer, bottom most effect in that layer) or last but before any glows or vignettes....
You should follow me on Twitter here. My latest work
John Cuevas
Re: Where in render stack should you use USM?
on Nov 22, 2013 at 2:28:40 am
USM?
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
jim bachalo
on Nov 22, 2013 at 3:10:00 am
UnSharpMasking
John Cuevas
on Nov 22, 2013 at 12:51:27 pm
Without knowing the effects you added to a layer it's pretty hard to say where you should place an unsharp mask. If I needed one, I'd probably place it first before glows/vignettes/color correction.
The order really won't change your render time, so experiment with it's placement in the stack and see if it looks better in one place more than others.
Thinkck.com
