Premiere CC - What effect can you use to have a clip fade from color to black and white?
Jen Gunkel
on Nov 21, 2013 at 5:28:18 am
What is the best way to turn a clip from color into black and white? I used both the Black and White and Desaturation filters and tried to use time remapping, but that did not work either. Any help is greatly appreciated.
John Cuevas
Re: Premiere CC - What effect can you use to have a clip fade from color to black and white?
on Nov 21, 2013 at 1:03:07 pm
This isn't the Premiere forum, but split your clip in two. Use a black and white part effect and then just dissolve between the two clips.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
