Easy Ease Glitch????
Dan Callahan
on Nov 14, 2013 at 8:06:36 pm
Alright, working on some compositions of still images. I have been using easy ease to smooth keyframe motion.
My problem is that even after I ctrl+click a keyframe to reset it, the easy ease motion is still applied even when the neighboring keyframe values are identical (think if both variables are set at 252; they will still fluctuate 4-6 points as if the easy ease is still applied.
Does anyone have an explanation for why this occurs? So that I don't have to completely scrap my layers and start over? I'm running CS 5.5; using .tiff files for the stills. I am precomping the image layer and adjusting the camera and precomp position variables to create the movement.
Thank you kindly.
Dave LaRonde
Re: Easy Ease Glitch????
on Nov 14, 2013 at 10:29:08 pm
Use the Toggle Hold Keyframe command on the INCOMING keyframe: it will keep the position steady until AE encounters the next keyframe, when the motion resumes.
Dave LaRonde
Promotion Producer
Dan Callahan
on Nov 15, 2013 at 5:57:18 pm
Thanks Dave! Worked like a charm.
