Is this done in Adobe After Effects?
Gustaf Garnow
on Nov 5, 2013 at 11:51:08 pm
Hello CreativeCow, newly registreted here in order to ask this question
I wonder if this video is done in After Effect?
Any idea and tips what program I should use in order to achieve something similiar and it's main purpose is for TV ad.
John Cuevas
Re: Is this done in Adobe After Effects?
on Nov 6, 2013 at 2:52:23 pm
You can do that in AE. It's hard to give you tips, as there are so many techniques used to create that 20 second spot. I did find a tutorial that might help you out. It's not video, but a slide show of some of the techniques, it should get you started though. After Effects tutorial: Papercut animation techniques revealed
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
