Edit value of keyframe (audio levels)
Sarah Williams
on Oct 30, 2013 at 1:03:08 am
I'm sorry if this is a stupid question but is there a way to edit the value of keyframes used for audio levels? I seem to be able to right click and edit values for position but it doesn't work when I try to do the same for audio levels. The option is there but when I click nothing happens.
Any advice would be appreciated.
John Cuevas
Re: Edit value of keyframe (audio levels)
on Oct 30, 2013 at 4:00:25 am
Open the audio panel, move the current time indicator to the keyframe and move the slider on the panel to edit the audio. Honestly, I'd hadn't tried to use the right click method before for audio---surprised it doesn't work.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Todd Kopriva
on Oct 30, 2013 at 3:53:51 pm
What happens for me is what's supposed to happen: The Audio panel opens and comes to the foreground.
After Effects team blog
John Cuevas
on Oct 30, 2013 at 4:19:35 pm
Ahhhh...I had the audio panel already open when I tested it, makes sense.
Thinkck.com
