Closing CS6 with Render Que running/paused
Alex Bryant
on Oct 24, 2013 at 1:47:15 am
Hello,
I have a small issue. I'm sure it's a dumb question, but can I close AE CS6 while an object is paused in the render que and come back to it later? My current render (due to my amateur status with AE, I didn't precomp much) is estimated at 49 hours. I need to be able to pause that, shut down the laptop, and come back to it. Is that possible?
John Cuevas
Re: Closing CS6 with Render Que running/paused
on Oct 24, 2013 at 11:15:45 am
It's not possible. If you need to start/stop rendering, I suggest you render to an image sequence file(TIF Sequence). That way if you stop, you can look at your files(they are tagged with a frame number) and pick up from there.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
