Background -Foreground Question
Lionel Bettinger
on Oct 7, 2013 at 4:40:07 am
Hi
I'm new to editing and have a question about background/foreground and distance. I'm creating a scene with after effects in front of a green screen with people walking. In Photoshop I have a matte picture that is going to used as the background. Whenever I scale it doesn't appear realistic, and doesn't fit the frame. Is there a way to make the foreground characters appear as if they are at full size and far away from the background region? I hope that makes sense.
John Cuevas
Re: Background -Foreground Question
on Oct 7, 2013 at 11:01:51 am
It sounds like you need a bigger background image. You could try scaling it up and blurring it---give it a fake depth-of-field look. Also another thing that goes a long way in making a background/foreground plate look like they belong together is color correction, so that everything is in the same hue, and seems to have the same light sources(s).
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Lionel Bettinger
on Oct 8, 2013 at 5:11:41 am
Thanks for your information. I will try this.
