Fixing the Boomerang effect?
Anders Hattne
on Oct 4, 2013 at 10:15:36 am
Hello, basic question here:
So I have a curved movement coming into a keyframe, then a pause (this is what causes the boomeranging) and then moves away.
I know that I can fix the problem changing spacial interpolation to linear, but then that will also straighten the curvy movement I had coming into the pause.
Can anyone point me to where I can learn how to fix this? (ie straightening only one of the handles. Also overlapping keyframes are difficult to get the right handle..)At the moment turning the first keyframe (of the identical boomerang keyframes) into a hold keyframe is my only work around. Are the more?
John Cuevas
Re: Fixing the Boomerang effect?
on Oct 4, 2013 at 11:28:30 am
AE Keyframe Boomerang Effect Tutorials.
See if those don't help and if you still have questions, we can work from there.
Johnny Cuevas, Editor
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
© 2018 All Rights Reserved
