CC Cylinder (Coca Cola effect)- Rotating logo
Elbire Rico
on Oct 2, 2013 at 10:06:27 am
Hello,
I know the theory of how this effect is done
Use the CC Cylinder and bulge to rotate de logo. But when it comes to the bottle, how do I place the logo behind it?
Thank you very much in advance.
Elbire
John Cuevas
Re: CC Cylinder (Coca Cola effect)- Rotating logo
on Oct 2, 2013 at 3:28:36 pm
If you mean the logo/bottle animation at the end, that was most likely done in a 3D app. That would be the easiest way to create that.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Elbire Rico
on Oct 2, 2013 at 3:40:44 pm
Thanks for the reply. This is what i did.
1.-I applied the CC Cylinder to the logo, and set the bottle as a track matte.
2.- Precom the layers and convert it to 3d.
3.- Finally I created a 3d null object to do the zoom effect.
The problem is that when it zooms the bottle and logo don't look sharp. I know it improves with the Continuous Rasterization but for that I need all the layers to be 3d, and that affects the track matte and the CC Cylinder.
How can this effect be done in 3D??
