Stroke edges
Marc Lucas
Stroke edges
on Sep 25, 2013 at 12:28:06 pm
Why am I getting two different edges of two different layers.
I've used a solid and masked out a section to use. The top one is fine view full screen but the bottom one is jagged
6556_screenshot20130925at13.24.11.jpg.zip
John Cuevas
Re: Stroke edges
on Sep 25, 2013 at 3:20:40 pm
Really you can't tell much from that picture. If you upload your project(really just that comp), I'll take a look and see if there's settings issue.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Marc Lucas
Re: Stroke edges
on Sep 25, 2013 at 3:41:23 pm
The bottom stroke is jagged might of been the position of the solid layer in the Comp?
I have changed the solid now and used a Shape layer and all is fine.
Thanks for the reply!
