Pausing a walk cycle issue
Al Wayson
on Sep 22, 2013 at 4:06:01 am
I have this:
comp 1:
- torso of a man
- leg 1
- leg 2
in this comp, the legs have a walk cycle. Comp time is 1 sec
comp 2:
- stage that man should walk over, stop for a few seconds, then walk off
comp 1 is placed in this comp with a loop_out("cycle", 0)
comp 1 is animated across this comp, stops for a while and then continues
My problem:
When the man stops, his legs are still cycling/walking.
What I've tried:
- Using the graph (edit speed graph) but it doesn't seem to work?
- Using the graph (edit value graph) but it won't let me edit the actual looping at the certain point in time (dashed lines).
Sorry if this is a basic question but I just can't find a way around it!
© 2018 All Rights Reserved
