Masking Confusion
Frank costabile
Masking Confusion
on Sep 21, 2013 at 6:22:18 pm
I have an image of a computer interface that I've imported from PS into AE. I want to place an animation of white noise static within the frame, but this is awkward as the outline of the frame is jagged and not perfectly square. I'm not familiar with the process of masking... how would I go about setting a mask around the edges of the frame so that the white noise stays within its confines?
Here's a screen capture: http://postimg.org/image/zf9gv9ut7/
Thanks in advance.
Frank
John Cuevas
Re: Masking Confusion
on Sep 21, 2013 at 9:49:50 pm
Why cabn't you just place the noise layer over your interface and mask the noise layer? Or you could duplicate your interface, make that the top layer, mask out the part where you want noise and set the noise's layer to use the top layer as an alpha matte.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Frank costabile
on Sep 21, 2013 at 10:02:03 pm
Cheers, I figured it out :)
