Drop Shadow on Multiple Planes
Grayson Wasteland
on Sep 3, 2013 at 5:14:33 pm
I am somewhat new to After Effects but have spent many hours in it so far on a few small projects.
I have a video of a spinning flower (masked out from a green screen) and am animating it to float down over a blue square. i was able to make a drop shadow for the flower which looks pretty good, but i wanted to add an ADDITIONAL drop shadow that effects the blue square to give the illusion that the flower is close to the square.
im not sure if this would be best done through drop shadows or through 3d layers and lights. I'm not sure if the 3d lights in AE know only to effect just the flower (masked) part of the green screen video or if it treats videos just as a rectangle...
thanks for your help!
John Cuevas
Re: Drop Shadow on Multiple Planes
on Sep 4, 2013 at 11:07:42 am
If you created a 3d blue square, use a light. AE will only use the masked portion
Johnny Cuevas, Editor
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
© 2018 All Rights Reserved
