Rotate a video created with Android phone
Diana Hoober
on Aug 29, 2013 at 3:36:15 am
I took a video with my Galaxy S III and uploaded to my laptop and it is sideways. I opened it in After Effects and I know it can be rotated but how? It is in the Composition window but at the top it says Composition (none). I saved a copy of it so is there something I should do like select all and rotate like with a picture in PS? I can't find basic information on how to do this.
John Cuevas
Re: Rotate a video created with Android phone
on Aug 29, 2013 at 11:46:41 am
Import your video into AE and chick on it in the project window. Drag the video on to the Make New Comp window. Press Cntl+K to open up the composition settings. Next to the comp dimensions uncheck the "gang/chain" icon and reverse the dimensions. X to Y, Y to X. Finally press "R" to access rotation and rotate the video +/- 90 degrees.
Johnny Cuevas, Editor
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
© 2018 All Rights Reserved
