Orientation
Lukas Radwan
Orientation
on Aug 21, 2013 at 11:34:06 am
Hi, I have a simple question for You?
I just created a beam effect with elipses.
When I change orientation of camera, these elipses change it too.
Is it possible that after the change orientation of lines, orientation of the elipses stay the same as before?
See this: http://dash.com.pl/screen.png
John Cuevas
Re: Orientation
on Aug 21, 2013 at 2:34:01 pm
Not exactly sure of your setup, but you should be able select the ellipses and press "cntl+alt+O(the letter)" to open the Auto-Orientation box and select Orient Towards Camera to achieve that effect.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Lukas Radwan
Re: Orientation
on Aug 21, 2013 at 3:23:53 pm
Incredible, it works! Thank You!
John Cuevas
Re: Orientation
on Aug 21, 2013 at 4:21:13 pm
Glad to help.
Thinkck.com
