Video Showing In China
Bobby Taylor
on Aug 16, 2013 at 3:39:39 pm
I am using after effects cs 5.5, and i was wondering what settings i should be using for my video showing in China, it will be showing in a university, and i think ive heard they use PAL instead of NTSC, is that the only difference, Thanks - Bobby
Thomas Leong
Re: Video Showing In China
on Aug 16, 2013 at 7:19:19 pm
It does not really matter these days.
Broadcast standard in China is PAL 25fps. But if played at a presentation, any format will do - their equipment is multi-format compatible (or chances are the rental company there will transfer to a laptop and play it off that).
Just supply the best quality that satisfies you and your client.
Bobby Taylor
on Aug 16, 2013 at 7:54:25 pm
Thank you so much, i really appreciate it, i was hoping that was the case, i was thinking that too, alright, thanks again -bobby
Thomas Leong
on Aug 17, 2013 at 5:25:53 am
On second thoughts, suggest you provide at least 2 options suitable for playback on a pc (rather than a mac) -
1 x high bit-rate MPRG-2 (10-20mbps; or maybe 2, one at 10mbps, one at 20mbps);
1 x H264
Thomas
Thomas Leong
Re: Video Showing In China - correction
on Aug 17, 2013 at 11:02:21 am
my bad:...kbps, not mbps.
