Output Modules
Marc Lucas
Output Modules
on Aug 2, 2013 at 10:29:20 am
Just getting into setting up Output Modules for group outputs. I usually export out of AE as ProRes 422 & 4444 (for the alpha) when I go into the custom output module settings (not custom panel where you set up your own) the format gives you QT as an option but when you go into custom settings the QT options is QT DV PAL is that the same or different?
What exactly is the Lossless setting in the Output Module Templates because it says Output info Animation but I would prefer ProRes how do you change to ProRes.
Dave LaRonde
Re: Output Modules
on Aug 2, 2013 at 5:08:21 pm
Something may not be set up properly on your machine. If you run BOTH FCP and AE on the same machine, you should have access to the ProRes codecs. You should also look at every tiny little dropdown and adjustment in the Output Module settings to ensure you didn't overlook something -- hey, it happens.
Using AE on a different machine? Sorry, no ProRes.
Dave LaRonde
Former Sr. Promotion Producer
