Problem with Puppet tool!
Zakaria Ounis
on Jul 24, 2013 at 2:05:56 am
OK, so i want to use puppet tool+ rotation to animate an arm.
i put down three pins and a key-frame at current time and adjust pins to give it a natural look;
move a couple of frames rotate the arm and boom,
weird thing happened,it seems like the pins dose not follow up with rotation or something!
please help me on this.
Zakaria Ounis
Re: Problem with Puppet tool!
on Jul 24, 2013 at 7:50:36 pm
I tried to render out, and this was the result.
Mark Boxall
on Jul 30, 2013 at 9:53:22 am
Have you tried pre-comping the arm layer adding the rotation to the pre-comp, and animating the puppet tool within the comp?
Zakaria Ounis
on Jul 30, 2013 at 9:15:05 pm
i tried your method, it was a bit tricky to animate..., but here is the result.
Mark Boxall
on Jul 30, 2013 at 9:47:23 pm
Good stuff. If you're interested in doing more character animation, if you haven't already, it's definitely worth checking out DuIK IK tool (http://duduf.net/?page_id=167). It's a free AE plug in and can save a lot of time once you've got you're head round how it works. Here's a couple of links to some tutorials on how to use it.
And here's how it works with the puppet tool
Good Luck
Zakaria Ounis
on Jul 31, 2013 at 12:37:19 am
thanks!, I've seen that tool before but i didn't know it works with puppet tool!
