Simplistic ripple?
Eric Chard
Simplistic ripple?
on Jul 16, 2013 at 3:10:07 am
(I thought this would be easy... d'oh!)
Trying to do a simple ripple effect: in this case the ripple is a simple sine-wave on a text layer, and the ripples displace the text only horizontally. There should be ~10 ripples along the height of an "L" for instance.
Trickier than I thought, at least for what I thought would be the logical approaches.
Ripples should be equal across the length of the word, i.e. not radial in any way.
THANKS!
"Putting the HARM in 'harmonica' since 2005."
Eric Chard
Re: Simplistic ripple?// required precomping
on Jul 16, 2013 at 2:12:44 pm
Got it:
use CHECKERBOARD + BLUR to create procedural horizontal lines
then PIXEL DISPLACEMENT on h. only.
Trivial once I figure out that DISPLACEMENT Layers must be precomped, as the effect ignores the, errrr, effect of other effects.
Emmanuel Jimenez
on Aug 5, 2013 at 5:31:14 pm
Another thing you can do it blur the radio waves effect and use that as a ripple.
Just a thought.
I rock.
