Twitch Filter
Shannon Vavrinchik
Twitch Filter
on Jul 5, 2013 at 11:48:25 pm
Hi
I'm using the Twitch filter.
I have it only affecting the text.
When the movement occurs I get some text cut off from the last letter in the word from the actual filter effect.
Does anyone know why this may be happening or a way around it?
chris brett
Re: Twitch Filter
on Jul 6, 2013 at 12:40:22 pm
Hi Shannon
- do not use twitch but sounds like the type is animating outside of its compostion area --
-- suggest you try pre-comping the type then, whilst in the pre-com panel, change the compostion size ( of the precomp ) to something which has LOTS of space around the type so that when it moves it does not get cut off ....
---- may not do the trick but fair chance I think ....
------------------- good luck ------chris
Shannon Vavrinchik
Re: Twitch Filter
on Jul 10, 2013 at 8:01:08 pm
Thanks Chris.
That did the trick.
I had other filters on the pre-comp but not the twitch filter.
Thanks again!
