Basics: Animated line that fades away
Brian Beech
on Jul 1, 2013 at 3:16:42 am
I'm a VJ and projection mapper. I'm just getting started in AE and I have a few beginner's projects I'd like to complete in order to get on the right track.
I'm using masks and stroke to create a line that follows a predetermined path while leaving a dragging tail that fades away behind it (Not just a solid end)
Here is what I'm trying to replicate:
EDIT: adding link:
(skip to 00:50)
Here you can see lines like I am describing, as well as lines that fully-stroke their paths quickly, then fade away (This I have figured out)
Should I be adjusting the timing for Opacity, or is it something else?
Any help would be appreciated.
John Cuevas
Re: Basics: Animated line that fades away
on Jul 1, 2013 at 2:25:17 pm
Good idea to give us a video example of what you are trying to accomplish, but you forgot the link.
Being new, take a look at this training page Todd Kopriva has compiled: Getting started with After Effects (CS4, CS5, CS5.5, CS6, & CC)
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Brian Beech
on Jul 1, 2013 at 3:28:42 pm
Oops. Here it is:
I'll definitely check those out.
Stephen Smith
on Jul 1, 2013 at 3:41:36 pm
It's a great tutorial that I think will get you pointed in the right direction.
Stephen Smith - Follow me on Behance
Utah Video Productions
Check out my Vimeo page
Stephen Smith
on Jul 1, 2013 at 3:35:42 pm
Take a look at this tutorial: http://www.videocopilot.net/tutorials/graffiti_writing/
