3 point transform?
Jan van der Bee
3 point transform?
on Apr 30, 2014 at 3:21:38 pm
Hi all,
I'm relatively new in After effects but i'm trying to transform a bitmap that has the shape of a triangle.
The only transformation effects i could find have 4 transform-points (like cc power pin). All i need/want are 3 transform points: one for every corner...
I've tried some scripting, but to no avail. Does anybody maybe know a solution for this?
Thanks in advance!
Todd Kopriva
Re: 3 point transform?
on Apr 30, 2014 at 6:48:36 pm
Depending on what you're trying to do, the Reshape effect may be what you need:
http://helpx.adobe.com/en/after-effects/using/distort-effects.html#reshape_...
After Effects team blog
John Cuevas
on Apr 30, 2014 at 4:37:57 pm
Try using the puppet tool.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
