Targeting a Light at a 3D layer
Eric Chard
on Jun 13, 2013 at 5:13:41 am
I wanted to target a light at a layer, so I used the pickwhip to substitute the layer's position for the lights POI.
This worked fine.
However, I wanted greater control, and the ability to fine-tune and otherwise animate the lite's target, so I did something that would work perfectly in my 3D app, but doesn't in AE:
I created a Null, and parented it to the moving layer.
I pickwhipped the Null's position the same way I did before, for the lights POI position.
Sadly, this did not work. In 3D terms I need the 'world coordinates' of the null, not the keyframed coords, since they just sit at 0/0/0.
How can one get the light to follow the NULL, with the null parented to the moving layer?
Suggestions?
Thanks.
"Putting the HARM in 'harmonica' since 2005."
John Cuevas
Re: Targeting a Light at a 3D layer
on Jun 13, 2013 at 5:13:54 pm
Eric, post your question in the Expressions Forum, I know there is a way to do this, but I just can't seem to work it out, where Dan or Kevin will probably be able to work this out immediately.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Eric Chard
on Jun 13, 2013 at 5:24:53 pm
Will do, thanks for the suggestion!
