Skew 3d Text with after effects
Juan Manuel Palomino Domínguez
on Jun 4, 2013 at 4:46:12 pm
Hi, i wonder about to skew a 3d text with after effects as you do with photoshop. Im not talking about an animate presets, i wonder about to do that in a no animated layer.
John Cuevas
Re: Skew 3d Text with after effects
on Jun 5, 2013 at 12:48:08 am
Take your text layer and twirl it open and use the Animate flyout to skew the layer.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
on Jun 5, 2013 at 10:47:40 am
May you explain your point better, cause i dont understand if youre talking about a tool or an effect. Im talking aboout doing this, te second line text:
http://www.google.com.ar/imgres?um=1&safe=off&sa=N&biw=1366&bih=664&hl=es-4...
It seem to be so simple, but in AE i dont know the way for doing this. Tank you.
John Cuevas
on Jun 6, 2013 at 12:36:11 am
Create a line of text and open up it's properties. There is a button(flyout) called "Animate", select it. Now select "Skew", when you do so, you will get a skew property you can animate.
Here's a link to some basic tutorials on how to use the text animators in after effects, the first one in the series is "Animating Source Text" :
http://blogs.adobe.com/aftereffects/2012/02/after-effects-basics-tutorials-...
Thinkck.com
on Jun 6, 2013 at 2:15:34 am
many tanks, u got the key
John Cuevas
on Jun 6, 2013 at 10:14:24 am
Glad I was able to help.
Thinkck.com
