Particles Not Following Emitter
Zach Johnson
on Jun 2, 2013 at 5:35:06 am
I'm having a lot of trouble with particles right now. I've been trying to solve this issue for the past several hours.
I'm using particular and I have it set to Lights as the emitter. However, it barely follows the lights. Sometimes it follows it perfectly, but most other times it goes off of the keyframes track and bounces all of the screen. How can I make the particles follow the emitter?
John Cuevas
Re: Particles Not Following Emitter
on Jun 2, 2013 at 2:24:48 pm
Open up your comp with your particular settings(emitter settings) and do a screen grab and post the picture here. Just not enough information right now to diagnose the problem.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
