Missing: Saber_Controls
Shawn Quintero
on May 10, 2013 at 5:20:11 am
So I looked on a couple of forums and couldn't find the answer. I'm currently using After Effects CS6. I'm trying to use the "Light_Saber_V2" plug-in from Andrew Kramer, but everytime I try to use it, the following error pops up:
"After Effects warning: Class 'Effect' has no property or method named
'Soften'
Expression disabled.
Error occurred at line 2.
Comp: 'Intro'
Layer: 9 ('Intro.mov')
Property: 'Blurriness'"
It's always giving me a "Missing: Saber_Controls" error, that won't even allow me to see the light saber effect on a new solid.
If anyone could help me, I would absolutely appreciate it. Thank you so much!
John Cuevas
Re: Missing: Saber_Controls
on May 10, 2013 at 1:55:57 pm
I just applied the preset to a solid and it worked. I did get "Missing: Saber_Controls" but everything actually works with it. Is your version of CS6 updated to 11.0.2.12?
And just in case, here's the VCP preset I'm using: 5984_lightsaberv2.1shortcut.zip
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
