How do you do these special effects in this video?
Vicky Carter
on May 2, 2013 at 6:15:23 pm
In this video:
http://www.blockandballfilms.co.uk/Portfolio.asp
Click on the Hampshire Constabulary video.
How do they do the opening text affect?
How did they do the blurry person effect at: 1.33- 1.38
The moving game board at: 2.08 and 2.24
John Cuevas
Re: How do you do these special effects in this video?
on May 2, 2013 at 8:35:43 pm
Looks like that was done in a 3D application, based on the shadows. If perfectly accurate shadows aren't important, you could make something very simliar in AE. Create a composition and place your text. Next you would create the edge wipe, either use a mask or the effect Transition > Linear Wipe. Place this comp into a new composition and apply the effect CC Cylinder.
Looks like the echo effect
This one could be built in AE if one really wanted to take the time to create a 3d environment, but if I had to guess, I'm pretty sure it was built in a 3d app, just would be a lot easier.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
