Scribble effect is not recognizing mask
Rizwan Rehmtulla
on Apr 20, 2013 at 5:38:38 am
I've live traced an image and have applied stroke to it.
Now I have copied that layer and put it on top to apply the scribble effect as a grand finale. However, using all masks using modes makes scribble not recognize one mask properly and simply won't fill it. If I change the mode of that mask to invert it works but nothing else.
Anyone who's encountered this problem?
In need of help.
John Cuevas
Re: Scribble effect is not recognizing mask
on Apr 20, 2013 at 2:49:20 pm
Without seeing your composition and effect stacks and masks it's a bit hard to determine the exact problem(if you want to upload your project here, I'll take a look), but as a work around, you could make multiple layers with the different masks and apply scribble to each one.
Johnny Cuevas, Editor
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
© 2018 All Rights Reserved
